[Gdal-dev] MapInfo style string
Frank Warmerdam
warmerdam at pobox.com
Wed Jun 21 11:14:45 EDT 2006
Richard Matsunaga wrote:
> In the course of my memory leak investigation, I noticed that using a
> style string with MapInfo is a very finicky beast. If your string is not
> formed correctly, it does not get caught when you set the string, but
> rather it crashes later when you create the feature on the layer.
> Can this be improved to parse the string better or at least return an
> error gracefully?
Richard,
If you can submit one (or more) bug reports demonstrating the problem
we can at least make things unlikely to crash.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
