[Gdal-dev] import gdal, a installation problem
Didrik Pinte dpinte at itae.be
Tue Jun 27 12:12:06 EDT 2006
Le mardi 27 juin 2006 à 09:42 -0400, Ivan Lucena a écrit :
> It is working fine, except that I can't do:
> 	C:/Data> Python pct2rgb.py
> I need to inform the full script path:
> 	C:/Data> Python "C:\Program Files\Gdal-1.3.2\bin\pct2rgb.py"
when calling python from the command line, it's not the argument that
are "path completible"...
It's the rigth way to do it.
If your python installation is correct, you must be able to do :
c:\Data>pct2rgb.py
or
c:\Program Files\Gdal-1.3.2\bin>python pct2rgb.py
Didrik
Name: not available
Desc: Ceci est une partie de message
	=?ISO-8859-1?Q?num=E9riquement?= =?ISO-8859-1?Q?_sign=E9e?=
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060627/2c160fe4/attachment.bin
