[Gdal-dev] ng python bindings
Frank Warmerdam
warmerdam at pobox.com
Tue Jun 27 12:14:58 EDT 2006
Vincent Schut wrote:
> Hi all,
> I wondered (after some resultless google searching): is there some howto
> lingering somewhere on how to build, install and use the ng python bindings?
Vincent,
On linux/unix it *should* be sufficient to configure using the
"--with-ngpython --without-python" options. Then build and install.
> Next to that, I remember having seen some messages come by on the numpy
> mailing list about having the gdal python ng bindings use numpy instead
> of numeric as it's supported array library. Because I'm using numpy
> mostly today, I wondered if this will really be the case, and if there
> is already any progress on having gdal bindings that natively support
> numpy instead of Numeric.
Mateusz has not yet completed the work on numpy support for the NG bindings.
I believe currently the ng bindings lack integration with numpy or numeric.
So, you might want to stick to the old bindings for a few more weeks till
the upgrade is ready.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
