[Gdal-dev] Problems with ogr2ogr?
    Moskovitz, Bob
    Bob.Moskovitz at conservation.ca.gov
    Tue Jun 27 13:25:17 EDT 2006
Hello Frank,
There was a problem when I ran those commands on my Linux box (which is not connected to the Internet).  So, I re ran those commands on my Windows box (which is on the Internet), assuming that I would get the same results.  Looks like I was wrong.
I am using the GDAL 1.3.1 Windows binary and I compiled GDAL 1.3.2 on my Linux box.  Below is the results of running GDAL on my Linux box.  Thank you for looking into this.
Bob
ogrinfo -al -so LAND_AP_7.tab
Had to open data source read-only.
INFO: Open of `LAND_AP_7.tab'
using driver `MapInfo File' successful.
Layer name: LAND_AP_7
Geometry: Polygon
Feature Count: 6
Extent: (2452634.218712, 276580.102129) - (2486216.118198, 322063.122454)
Layer SRS WKT:
PROJCS["unnamed",
    GEOGCS["unnamed",
        DATUM["NAD_1927",
            SPHEROID["Clarke 1866",6378206.4,294.9786982],
            TOWGS84[-8,160,176,0,0,0,0]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433]],
    PROJECTION["Lambert_Conformal_Conic_2SP"],
    PARAMETER["standard_parallel_1",34.0333333333],
    PARAMETER["standard_parallel_2",35.4666666667],
    PARAMETER["latitude_of_origin",33.5],
    PARAMETER["central_meridian",-118],
    PARAMETER["false_easting",609601.2],
    PARAMETER["false_northing",0],
    UNIT["U.S. Foot",0.3048006]]
AREA: Real (0.0)
PERIMETER: Real (0.0)
LAND_AP_7_: Integer (0.0)
LAND_AP_7_ID: Integer (0.0)
ogr2ogr -f "MapInfo File" -s_srs EPSG:26745 -t_srs EPSG:26711 test.tab LAND_AP_7.tab
ogrinfo -al -so test.tab
INFO: Open of `test.tab'
Layer name: test
Geometry: Polygon
Feature Count: 5
Extent: (545973.839059, 3789822.182688) - (556088.117459, 3803682.581444)
Layer SRS WKT:
PROJCS["unnamed",
    GEOGCS["unnamed",
        DATUM["WGS_1984",
            SPHEROID["WGS 84",6378137,298.257223563],
            TOWGS84[0,0,0,-0,-0,-0,0]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-117],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    UNIT["Meter",1.0]]
AREA: Real (0.0)
-----Original Message-----
From: Frank Warmerdam [mailto:fwarmerdam at gmail.com]On Behalf Of Frank
Warmerdam
Sent: Tuesday, June 27, 2006 9:31 AM
To: Moskovitz, Bob
Cc: Gdal-Dev (E-mail)
Subject: Re: [Gdal-dev] Problems with ogr2ogr?
Moskovitz, Bob wrote:
> Hello List,
> I am a new user of GDAL./OGR and I have a problem converting (what is
> supposed to be) a NAD27 California State Plane Zone 5 Mapinfo file to a
> NAD27 UTM Zone 11.  For some reason ogr2ogr created a file that
> uses WGS84. The source file was created with MapInfo 6. This is what I did:
> *ogr2ogr -f "MapInfo File" -s_srs EPSG:26745 -t_srs EPSG:26711 test.tab
> LAND_AP_7.tab*
> *ogrinfo -al -so test.tab*
> Layer name: test
> Geometry: Polygon
> Feature Count: 5
> Extent: (545973.840000, 3789822.180000) - (556088.130000, 3803682.585000)
> Layer SRS WKT:
> PROJCS["unnamed",
>     GEOGCS["unnamed",
>         DATUM["North_American_Datum_1927",
>     UNIT["Meter",1.0]]
Bob,
I'm not clear on why you think the output file is in WGS84.  The
above report from ogrinfo is UTM 11 NAD27.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
