[Gdal-dev] Compiler error
Frank Warmerdam
warmerdam at pobox.com
Wed Mar 1 07:50:55 EST 2006
Martin Rodriguez wrote:
> Hello,
> I 've a problem with FWTools, I develope an application for Windows
> using FWTools but now, I need to build it for Linux, my code is not the
> problem because is standard C++.
> But I need use FWTools for Linux, I'm testing FWTools in Linux with an
> easy sample and I have the next problem:
> [root at knoppix FWTools-linux-1.0.0a7]# gcc main.cpp -I include -L lib -o
> main
> main.cpp: In function `int main()':
> main.cpp:11: `OGRResgisterAll' undeclared (first use this function)
> main.cpp:11: (Each undeclared identifier is reported only once for each
> function it appears in.)
Martin,
Are you sure line 11 shouldn't be calling OGRRegisterAll() instead of
OGRResgisterAll()? I'm not sure how this would work on windows either.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
