[Gdal-dev] gdal-1.3.1 installation: gdal-config, gdal_translate,
gdalinfo all show different versions
Nagesh Bhatkar
bnagesh at nio.org
Wed Mar 8 04:25:32 EST 2006
Hello Gdal Users,
I used the following command:
urmpe gdal
to remove any versions of gdal installed in the system.
That solved my problem.
Regards
Nagesh
Nagesh Bhatkar wrote:
> Dear GDAL Users,
> I installed gdal-1.3.1 on mandriva 2006,
> now i get the following
> gdal-config --version
> 1.3.1
> which gdal-config
> /usr/local/bin/gdal-config
> gdal_translate --version
> GDAL 1.2.6.0, released 2005/03/13
> which gdal_translate
> /usr/local/bin/gdal_translate
> gdalinfo --version
> which gdalinfo
> /usr/local/bin/gdalinfo
> Looking above one can notice that there may be more than one version
> of gdal
> installed on the system , which i think is not the case because after
> slocate
> i dont find any gdal 1.2.6 on my system
> If i want to remove all existing installations (if any) of the gdal
> library,
> what are the steps i need to follow. So that i can install the new
> version
> fresh.
> Kindly help.
> Nagesh Bhatkar
> National Institute of Oceanography
> India- Goa
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
