[Gdal-dev] gdal-1.3.1 installation: gdal-config, gdal_translate,
gdalinfo all show different versions
Frank Warmerdam
warmerdam at pobox.com
Wed Mar 8 08:29:43 EST 2006
Nagesh Bhatkar wrote:
> Dear GDAL Users,
> I installed gdal-1.3.1 on mandriva 2006,
> now i get the following
> gdal-config --version
> 1.3.1
> which gdal-config
> /usr/local/bin/gdal-config
> gdal_translate --version
> GDAL 1.2.6.0, released 2005/03/13
> which gdal_translate
> /usr/local/bin/gdal_translate
> If i want to remove all existing installations (if any) of the gdal
> library,
> what are the steps i need to follow. So that i can install the new version
> fresh.
Nagesh,
The difference between gdal-config and gdal_translate or gdalinfo is that
gdal-config is reporting the version burned into the "mainline" (the
file /usr/local/bin/gdal-config) while the others are reporting the
version in the shared library (libgdal.so). So, presumably what is
happening is a different shared library is being picked up and used.
Like /usr/lib/libgdal.so.
You can find out what shared libraries are being used with the ldd
command.
eg.
ldd /usr/local/bin/gdalinfo
How to remove all existing installations depends on how they were installed.
You might want to do "locate libgdal" to find installed versions of the
library.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
