[Gdal-dev] tiff errors on gdaladdo
Bart van den Eijnden bartvde at xs4all.nl
Wed Mar 8 05:02:45 EST 2006
Hi list,
we are trying to build overviews using gdaladdo but are running into errors:
0...10...20...30...40...50...Warning 1: 765/b765-1924.tif:PackBitsDecode:
discarding 2 bytes to avoid buffer overrun
60..Warning 1: 765/b765-1924.tif:PackBitsDecode: discarding 2 bytes to
ERROR 1: 765/b765-1924.tif:PackBitsDecode: Not enough data for scanline 128
ERROR 1: TIFFReadEncodedTile() failed.
.70...80...ERROR 1: 765/b765-1924.tif:PackBitsDecode: Not enough data for
scanline 1920
ERROR 1: IReadBlock failed at X offset 15, Y offset 9
ERROR 1: GetBlockRef failed at X block offset 15, Y block offset 9
90.ERROR 1: 765/b765-1924.tif:PackBitsDecode: Not enough data for scanline
1920
..ERROR 1: 765/b765-1924.tif:PackBitsDecode: Not enough data for scanline
1920
ERROR 1: IReadBlock failed at X offset 1, Y offset 0
ERROR 1: GetBlockRef failed at X block offset 1, Y block offset 0
Is this solveable? Or is it a problem of the source tiff files?
Best regards,
Bart
