[Gdal-dev] problem with ogr2ogr -f PostgreSQL...
Ethan Alpert ealpert at digitalglobe.com
Wed Mar 8 12:17:47 EST 2006
I'm running CVS from March 1 and OGR does not have any option to set
SRID but it does manage to create a constraint that the SRID should be
-1.
-e
-----Original Message-----
From: Chapman, Martin [mailto:MChapman at sanz.com]
Sent: Tuesday, March 07, 2006 5:13 PM
To: Ethan Alpert; Thom DeCarlo; gdal-dev at lists.maptools.org
Subject: RE: [Gdal-dev] problem with ogr2ogr -f PostgreSQL...
I pointed that out to Frank a week or two ago and I think it's fixed in
the daily version now.
Martin
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Ethan Alpert
Sent: Tuesday, March 07, 2006 4:40 PM
To: Thom DeCarlo; gdal-dev at lists.maptools.org
You know what I suggest using shp2pgsql with psql -f to load data and
psql to create the indexes. You're just going to run into problems
because the ogr PG driver doesn't set the SRID.
-e
[mailto:gdal-dev-bounces at lists.maptools.org] On Behalf Of Thom DeCarlo
Sent: Tuesday, March 07, 2006 3:22 PM
To: gdal-dev at lists.maptools.org
Subject: [Gdal-dev] problem with ogr2ogr -f PostgreSQL...
I've set up my PostGIS-enabled PostgreSQL database and created a dataset
called "spatial". I have several shapefiles that I want to load into a
single layer. I found the instructions on the gdal website but when I
specify a layername at the end of the ogr2ogr command it quietly fails.
That
is, no messages of any kind either at the command line nor in the pgsql
logfile. If I don't specify a layername the command works just fine.
Are there known problems with this function? I'm using PostGIS 1.1.0 and
PostgreSQL 8.1.1 on RHEL3.
Thanks,
Thom
Thom DeCarlo
             Who is General Failure
         and why is he reading my disk?
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
