[Gdal-dev] gdaladdo problems on an Mac OS X Panther
Wed Mar 15 11:31:39 EST 2006
Gross, Dorit (SDRN) wrote:
> Dear list,
> I use gdaladdo to add overviews to a GeoTiff and receive following error
> message:
> /usr/local/gislibs/bin/gdaladdo -r average --config COMPRESS_OVERVIEW LZW
> /Artemis/public/spot-veg/ndv/2006/dv06031_wrld.tif 2 4 8 16 32 64 128
> 0.Warning 1:
> TIFFReadDirectory:/Artemis/public/spot-veg/ndv/2006/dv06031_wrld.tif: Wrong
> "StripByteCounts" field, ignoring and calculating from imagelength Warning 1:
> ..10...20...30...40...50...60...70...80...90..Warning 1:
> "StripByteCounts" field, ignoring and calculating from imagelength ERROR 1:
> /Artemis/public/spot-veg/ndv/2006/dv06031_wrld.tif:DumpModeDecode: Not enough
> data for scanline 0 ERROR 1: TIFFReadEncodedTile() failed.
> ERROR 1: IReadBlock failed at X offset 0, Y offset 4
> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 4 ERROR 1:
> Any ideas what could be the problem and how it could be solved?
> We use the latest GIS Libs for Mac OS X Panther (2.2.1) including GDAL/OGR
> v1.3.1 downloaded from Kyng Chaos.
Dorit,
It *sounds* like the input file may be corrupt in some sense.  Was it
generated with libtiff?  Can you make the original file available for
me to look at?
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
