[Gdal-dev] gdaladdo problems on an Mac OS X Panther
William Kyngesburye
woklist at kyngchaos.com
Thu Mar 16 09:49:48 EST 2006
What about other TIFFs?
I'd like to get the image also so I can check my GIS Libs builds.
I'll try some of my own TIFFs also. There may a problem with my
distribution.
On Mar 16, 2006, at 2:30 AM, Gross, Dorit (SDRN) wrote:
> Hi Frank,
> The original file is a SPOT VGT HDF that was converted into GeoTiff
> using
> gdal_translate. The overviews are added just in the next step. The
> script was
> running before the upgrade of GIS Libs. I tried the script for
> different SPOT
> files after the upgrade but receive now the same error message for
> all of
> them.
> I can provide you an image. Please let me know where it can be
> uploaded to.
> Regards,
> Dorit
> -----Original Message-----
> From: Frank Warmerdam [mailto:fwarmerdam at gmail.com] On Behalf Of Frank
> Warmerdam
> Sent: 15 March 2006 17:32
> To: Gross, Dorit (SDRN)
> Cc: gdal-dev at lists.maptools.org
> Subject: Re: [Gdal-dev] gdaladdo problems on an Mac OS X Panther
>> Dear list,
>> I use gdaladdo to add overviews to a GeoTiff and receive following
>> error
>> message:
>> /usr/local/gislibs/bin/gdaladdo -r average --config COMPRESS_OVERVIEW
>> LZW /Artemis/public/spot-veg/ndv/2006/dv06031_wrld.tif 2 4 8 16 32 64
>> 128 0.Warning 1:
>> TIFFReadDirectory:/Artemis/public/spot-veg/ndv/2006/dv06031_wrld.tif:
>> Wrong "StripByteCounts" field, ignoring and calculating from
>> imagelength Warning 1:
>> dv06031_wrld.tif: Wrong
>> "StripByteCounts" field, ignoring and calculating from imagelength
>> ..10...20...30...40...50...60...70...80...90..Warning 1:
>> Warning
> 1:
>> ERROR 1:
>> /Artemis/public/spot-veg/ndv/2006/dv06031_wrld.tif:DumpModeDecode:
>> Not
> enough
>> data for scanline 0 ERROR 1: TIFFReadEncodedTile() failed.
>> ERROR 1: IReadBlock failed at X offset 0, Y offset 4
>> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 4
>> ERROR 1:
>> Not
> enough
>> Any ideas what could be the problem and how it could be solved?
>> We use the latest GIS Libs for Mac OS X Panther (2.2.1) including
>> GDAL/OGR v1.3.1 downloaded from Kyng Chaos.
> Dorit,
> It *sounds* like the input file may be corrupt in some sense. Was it
> generated with libtiff? Can you make the original file available
> for me to
> look at?
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | President OSGF, http://
> osgeo.org
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
William Kyngesburye <kyngchaos at kyngchaos.com>
http://www.kyngchaos.com/
"This is a question about the past, is it? ... How can I tell that
the past isn't a fiction designed to account for the discrepancy
between my immediate physical sensations and my state of mind?"
- The Ruler of the Universe
