[Gdal-dev] gdaladdo problems on an Mac OS X Panther
Gross, Dorit (SDRN) Dorit.Gross at fao.org
Thu Mar 16 03:30:04 EST 2006
Hi Frank,
The original file is a SPOT VGT HDF that was converted into GeoTiff using
gdal_translate. The overviews are added just in the next step. The script was
running before the upgrade of GIS Libs. I tried the script for different SPOT
files after the upgrade but receive now the same error message for all of
them.
I can provide you an image. Please let me know where it can be uploaded to.
Regards,
Dorit
-----Original Message-----
From: Frank Warmerdam [mailto:fwarmerdam at gmail.com] On Behalf Of Frank
Warmerdam
Sent: 15 March 2006 17:32
To: Gross, Dorit (SDRN)
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] gdaladdo problems on an Mac OS X Panther
Gross, Dorit (SDRN) wrote:
> Dear list,
> I use gdaladdo to add overviews to a GeoTiff and receive following
> error
> message:
> /usr/local/gislibs/bin/gdaladdo -r average --config COMPRESS_OVERVIEW
> LZW /Artemis/public/spot-veg/ndv/2006/dv06031_wrld.tif 2 4 8 16 32 64
> 128 0.Warning 1:
> TIFFReadDirectory:/Artemis/public/spot-veg/ndv/2006/dv06031_wrld.tif:
> Wrong "StripByteCounts" field, ignoring and calculating from
> imagelength Warning 1:
> TIFFReadDirectory:/Artemis/public/spot-veg/ndv/2006/dv06031_wrld.tif: Wrong
> "StripByteCounts" field, ignoring and calculating from imagelength
> ..10...20...30...40...50...60...70...80...90..Warning 1:
> "StripByteCounts" field, ignoring and calculating from imagelength Warning
1:
> "StripByteCounts" field, ignoring and calculating from imagelength ERROR 1:
> /Artemis/public/spot-veg/ndv/2006/dv06031_wrld.tif:DumpModeDecode: Not
enough
> data for scanline 0 ERROR 1: TIFFReadEncodedTile() failed.
> ERROR 1: IReadBlock failed at X offset 0, Y offset 4
> ERROR 1: GetBlockRef failed at X block offset 0, Y block offset 4
> ERROR 1:
enough
> Any ideas what could be the problem and how it could be solved?
> We use the latest GIS Libs for Mac OS X Panther (2.2.1) including
> GDAL/OGR v1.3.1 downloaded from Kyng Chaos.
Dorit,
It *sounds* like the input file may be corrupt in some sense.  Was it
generated with libtiff?  Can you make the original file available for me to
look at?
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
