[Gdal-dev] OGR:GetNextFeature() throws exception in WINXP
Mateusz Łoskot
mateusz at loskot.net
Tue Mar 21 06:19:44 EST 2006
vdharan nadra wrote:
> Dear Mateusz Łoskot,
> Thanks for your suggestion.But I have made a mistake while pasting my
> code . The actual code is as follows and it still has the problem
> running in XP. I have also added the check for NULL layer as you have
> suggested. In XP i get the output of "printf( "%.3f,%.3f\n",
> poPoint->getX(), poPoint->getY() );" for few polygons and then the
> application crashes.
Is this possible for you to give us your shapefile you are
using with this code?
If it is, please publish it somewhere to download.
It would help much.
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
