[Gdal-dev] OGR:GetNextFeature() throws exception in WINXP
Vidhiyadharan Nadarajah
vdharan2001 at gmail.com
Mon Mar 20 21:38:06 EST 2006
You can down load the shape files from the following link
http://vdharan.741.com/india_ds.dbf
http://vdharan.741.com/india_ds.shp
http://vdharan.741.com/india_ds.shx
Best Regards,
N.Vidhiyadharan
-----Original Message-----
[mailto:gdal-dev-bounces at lists.maptools.org]On Behalf Of Mateusz Łoskot
Sent: Tuesday, March 21, 2006 4:50 PM
To: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] OGR:GetNextFeature() throws exception in WINXP
vdharan nadra wrote:
> Dear Mateusz Łoskot,
> Thanks for your suggestion.But I have made a mistake while pasting my
> code . The actual code is as follows and it still has the problem
> running in XP. I have also added the check for NULL layer as you have
> suggested. In XP i get the output of "printf( "%.3f,%.3f\n",
> poPoint->getX(), poPoint->getY() );" for few polygons and then the
> application crashes.
Is this possible for you to give us your shapefile you are
using with this code?
If it is, please publish it somewhere to download.
It would help much.
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
Internal Virus Database is out-of-date.
Checked by AVG Free Edition.
Version: 7.1.375 / Virus Database: 267.15.12/266 - Release Date: 21/02/2006
