[Gdal-dev] Mishandled "pixel is point" in geotiff
Tim Beckmann
tbeckman at usgs.gov
Tue Mar 21 15:50:37 EST 2006
Hi all (and Frank),
I sent an email to the list a few weeks ago about geotiff files with the
"Pixel is point" option not being handled properly by gdal. I only
received a reply from one person off the list stating that it was a known
problem.
I did figure out how to pass the "-mo AREA_OR_POINT=POINT" parameter to
gdal_translate to tell it to include the pixel is point indication in the
output geotiff file. So, my command line looks like:
gdal_translate -mo AREA_OR_POINT=POINT -co INTERLEAVE=PIXEL \
-a_srs "+proj=utm +zone=15 +datum=WGS84" \
-a_ullr 753600 3462900 801900 3260100 \
'HDF4_SDS:UNKNOWN:"EO1H0220392005002110P0_HDF.L1T":0'
testit_b001.tif
This results in the geotiff file properly indicating "pixel is point".
However, the reported pixel size is incorrect. It is being calculated
incorrectly from the provided corners like it was still "pixel is area"
(so instead of being 30 meters, it is just a little less than 30 meters).
The hack at the bottom of the email works around it by rescaling the pixel
size for the "pixel is point" case. But it doesn't do anything for
properly fixing the issue throughout gdal... (but it looks like the "pixel
is point" support itself is a hack...)
Tim
diff -u -r1.157 geotiff.cpp
--- geotiff.cpp 17 Feb 2006 15:46:06 -0000 1.157
+++ geotiff.cpp 21 Mar 2006 20:40:41 -0000
@@ -3786,6 +3786,20 @@
adfPixelScale[1] = fabs(adfGeoTransform[5]);
adfPixelScale[2] = 0.0;
+ /* if the metadata indicates the image is using "Pixel is
+ point", scale the pixel size since it has been
calculated
+ incorrectly. This is not the proper way to fix it,
but it
+ takes more knowledge to find the correct place to fix
it */
+ if( poSrcDS->GetMetadataItem( GDALMD_AREA_OR_POINT )
EQUAL(poSrcDS->GetMetadataItem(GDALMD_AREA_OR_POINT),
+ GDALMD_AOP_POINT) )
+ int nRasterXSize = poSrcDS->GetRasterXSize();
+ int nRasterYSize = poSrcDS->GetRasterYSize();
+ adfPixelScale[0] *=
(double)nRasterXSize/(nRasterXSize - 1);
+ adfPixelScale[1] *=
(double)nRasterYSize/(nRasterYSize - 1);
TIFFSetField( hTIFF, TIFFTAG_GEOPIXELSCALE, 3,
adfPixelScale );
adfTiePoints[0] = 0.0;
Tim Beckmann
Software Project Lead
Science Applications International Corporation (SAIC)
Contractor to the USGS/EROS
Sioux Falls, SD 57198
605-594-2521 Phone
605-594-6940 Fax
