[Gdal-dev] Mishandled "pixel is point" in geotiff
Frank Warmerdam
warmerdam at pobox.com
Tue Mar 21 16:28:36 EST 2006
Tim Beckmann wrote:
> Hi all (and Frank),
> I sent an email to the list a few weeks ago about geotiff files with the
> "Pixel is point" option not being handled properly by gdal. I only
> received a reply from one person off the list stating that it was a known
> problem.
> I did figure out how to pass the "-mo AREA_OR_POINT=POINT" parameter to
> gdal_translate to tell it to include the pixel is point indication in the
> output geotiff file. So, my command line looks like:
> gdal_translate -mo AREA_OR_POINT=POINT -co INTERLEAVE=PIXEL \
> -a_srs "+proj=utm +zone=15 +datum=WGS84" \
> -a_ullr 753600 3462900 801900 3260100 \
> 'HDF4_SDS:UNKNOWN:"EO1H0220392005002110P0_HDF.L1T":0'
> testit_b001.tif
> This results in the geotiff file properly indicating "pixel is point".
> However, the reported pixel size is incorrect. It is being calculated
> incorrectly from the provided corners like it was still "pixel is area"
> (so instead of being 30 meters, it is just a little less than 30 meters).
> The hack at the bottom of the email works around it by rescaling the pixel
> size for the "pixel is point" case. But it doesn't do anything for
> properly fixing the issue throughout gdal... (but it looks like the "pixel
> is point" support itself is a hack...)
Tim,
I'm not completely out of denial about PixelIsPoint. At some point I will
finally cave in and fix it, but it will need to be addressed in a variety
of places in the software. In the meantime you need to specify -a_ullr based
on the implicit pixel-is-area assumption of GDAL.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
