[Gdal-dev] Problem creating MapInfo tab files using C# (via the C API)
Tue Mar 21 17:41:20 EST 2006
Richard Matsunaga wrote:
> Hi all,
> I've been building a C# wrapper for OGR (following on the good work on a
> GDAL wrapper by Sy Perkins) and am very new to OGR development.
> Everything was going swimmingly until I tried to write to a MapInfo tab
> file. Basically, I am trying to write multiple layers, each with some
> number of polygon objects. All my fields are being written correctly.
> But for some reason, only the 2nd layer that I create is good. If I
> create only one layer, it is corrupt. All layers other than the 2nd
> layer are corrupt.
> How do I define corrupt? The files open in MapInfo, but the polygons
> have invalid coordinates and certain actions within MapInfo cause
> crashes (such as Export). The fields are all correct. If you check the
> projection in table maintenance, MapInfo cannot find the projection for
> all layers except the 2nd.
Richard,
This might be worth taking up on the mitab list - this issue sounds vaguely
familiar.  I wonder if it might already have been fixed. Are you using
GDAL CVS?
If you can boil down a small C program that demonstrates the problem that
would be helpful.  I don't have any mapinfo software myself though, so it
is hard for me to test files that cause it problems.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
