[Gdal-dev] Problem creating MapInfo tab files using C# (via the C API)
Daniel Morissette dmorissette at mapgears.com
Wed Mar 22 13:01:02 EST 2006
Frank Warmerdam wrote:
> This might be worth taking up on the mitab list - this issue sounds vaguely
> familiar.  I wonder if it might already have been fixed. Are you using
> GDAL CVS?
Frank,
Are you thinking of the problem with the #ifdef MITAB_AFFINE_PARAMS in
MITAB that causes unreadable files?
http://bugzilla.maptools.org/show_bug.cgi?id=1319
Richard: perhaps you could try recompiling GDAL after adding
-DMITAB_AFFINE_PARAMS to the CPPFLAGS variable in GDALmake.opt and let
us know if that solves the issue.
Daniel
Daniel Morissette
http://www.mapgears.com/
