[Gdal-dev] Batch export from a directory?
Matthew Perry
perrygeo at gmail.com
Sat Mar 25 20:05:18 EST 2006
Jonathan,
On 3/25/06, Jonathan Greenberg <jgreenberg at arc.nasa.gov> wrote:
> Is there a way to select a directory and batch export using gdal all
> workable image files to a single output format (modifying the extension as
> necessary?)
If you're using a bash shell, you might try a script along these lines:
outputdir=/home/newdata
inputdir=/home/data
cd $inputdir
for raster in *; do
gdalinfo $raster
# If gdalinfo returned exit code 0,
# we can assume its a valid raster image
if [ $? = 0 ]; then
# Assume the file prefix is everything before the first '.'
prefix=` echo $raster | sed 's/\..*//'`
# use gdal_translate to convert to ERDAS Imagine format
gdal_translate -of "HFA" $raster ${outputdir}/${prefix}.img
fi
done
Matt Perry
http://www.perrygeo.net
