[Gdal-dev] gdal_translate image grow
Frank Warmerdam
warmerdam at pobox.com
Thu Mar 30 09:10:58 EST 2006
Norman Barker wrote:
> Hi,
> I am using gdal_translate as the ‘engine’ behind mod_python as a very
> simple WMS (so that I can prototype a few ideas before putting them into
> MapServer), everything works fine until I specify a BBOX such that the
> extents are outside that of the requested image. This corresponds to
> the –projwin option of gdal_translate, executing this I then get an
> error “–srcwin falls outside of raster size”.
> Is there a way to grow the output image and fill in the missing data?
> So for example
> gdal_translate -not_strict -OF PNG -a_nodata 0 -projwin -180 90 180 -90
> -outsize 836 654 inputimage outputimage
> would give an output image with world extents, and somewhere in this
> image would be the inputimage
> Alternatively is there a way to do this with the python bindings or any
> other utility. I like gdal_translate since it does the conversion and
> sampling in one go!
Norman,
If you were willing to limit yourself to directly creatable formats,
you could use gdalwarp to do this. It supports an output file with a
larger region than the input. Alternatively a few modifications could
be made to gdal_translate to support a projwin (or srcwin) that is larger
than the source.
Another approach would be for you to prepare a VRT file as input to
gdal_translate in your VRT script that has the characteristics you want
relative to the original file. When you subwindow or do other such
transformations in gdal_translate it actually creates a "VRT" image of
the desired output file and uses that for input to translation. To get
an idea what these VRTs look like you can even do a gdal_translate to
VRT format and you will get the VRT skeleton it created.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
