[Gdal-dev] Error compiling gdal with MrSid support in ubuntu linux
Mikael Schröder miscx at spray.se
Thu Mar 30 17:04:52 EST 2006
Perfekt!
Thank you!!! It finally worked!
I will give the ecw-problem a try another day/night... (now that I got
MrSid working)
With "other C++ packages" you refer only to packages that depend upon
libgeos/libgdal right. like Qgis, mapserver etc.
What about PostGIS ??
/Best Regards, Mikael
tor 2006-03-30 klockan 16:47 -0500 skrev Frank Warmerdam:
> Mikael Schröder wrote:
> > This worked out fine but I found that I also needed to  compile
> > "libgeos" withe the same compiler, to get "libgdal" with ogr working.
> Mikael,
> Right, GEOS and other C++ packages will all need to be compiled with
> roughly the same version of gcc.
> > Unfortunately I did not manage to compile gdal with both MrSid and ECW
> > with gcc 3.2. So I disabled ECW for now... (any tips on this?)
> Well, I've built the ECW SDK with gcc 3.2 without problems, so you
> will need to be more specific if you need help.
> > When everything was compiled and installed I run:
> > $ gdalinfo --formats     to se if my newly installed packages were
> > functioning. Unfortunately I got the same error message as before the
> > installation, as me and the wrong one as root (se below). So I suppose
> > that my previous cvs-source-compiled "gdal" that I manage to install but
> > never got functioning is now somehow disturbing my system.
> > It seems my system is not responding on the gdal-package installation,
> > so how do I disable / uninstall my previously cvs-source-compiled and
> > installed "gdal" ?
> > I found no: "make uninstall". Or how do I change the system settings so
> > it will use my now correct libgdal-package instead of the source
> > compiled one?
> You would basically need to remove it manually or install over it.
> eg.
> rm /usr/local/lib/libgdal*
> > Below you find my current system's response to "gdalinfo --formats" both
> > as me and as root (with the new MrSid enabled libgdal-package installed
> > and "active").
> > Lots of questions....
> Best regards,
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060331/43dda1e9/attachment.html
