[Gdal-dev] RE: GDAL for windows CE
Vasku Pech
vaskup at adsmr.co.za
Tue May 2 05:37:31 EDT 2006
Hi Matues,
I cannot by any means connect to your CVS server. When I try entering the password it gives me the following reply:
Unknown host cvs.maptools.org
I have fllowed the procedure described on www.gdal.org. This is what it says:
___________________________________________________________
GDAL source releases are available in tar.gz and zip from
from the GDAL primary ftp site, and http mirror site:
http://www.gdal.org/dl
http://gdal.maptools.org/dl
The NEWS file describes features added up to the most
recent public release.
Late each night a development snapshot is captured from
CVS and made available. These snapshots are not stable
releases, and might (on a bad night) not even build.
However, they do contain essentially the latest code. They
can be downloaded from:
http://gdal.maptools.org/dl/daily
Refer to the build instructions for how to build GDAL from
source.
CVS
The GDAL source is available by anonymous CVS from the
cvs.maptools.org server:
% export
CVSROOT=:pserver:cvsanon at cvs.maptools.org:/cvs/maptools/cvsroot
% cvs login
Password: *enter*
% cvs checkout gdal
Update access to the CVS repository can be obtained by
arrangement with the maintainer.
____________________________________________________________________
My question is: Is pserver an alias for an IP address? If so please give me the IP address so I can add to my hosts file.
Regards,
Vasku
-----Original Message-----
From: Mateusz Loskot [mailto:mateusz at loskot.net]
Sent: 27 April 2006 02:20 PM
To: gdal-dev at lists.maptools.org
Cc: Vasku Pech
Subject: Re: GDAL for windows CE
Vasku Pech wrote:
> I use the workspace file supplied .vcw but it does not want to
> compile. It tells me that the .vcw and .vcp files where not created
> in embedded Visual C++.
Hmm, that's very strange.
Could you check if those .vcw/.vcw files have CR/LF line ends?
May be those files were converted to Unix LFs only and eVC++ can not
recognize them.
> I have tried to download a stable version of the software via the CVS
> site. When I enter the password *enter* it gives me the following
> reply: Unknown host cvs.maptools.org
Strange. I use GDAL CVS every day and it works.
Please, try to follow this procedure:
C:\tmp\gal$ cvs -d
:pserver:cvsanon at cvs.maptools.org:/cvs/maptools/cvsroot login
Logging in to :pserver:cvsanon at cvs.maptools.org:2401/cvs/maptools/cvsroot
CVS password: *ENTER*
C:\tmp\gal$ cvs -z3 -d
:pserver:cvsanon at cvs.maptools.org:/cvs/maptools/cvsroot checkout gdal
> Can you please tell me where I can download the Windows CE port of
> gdal with the correct make files or project/workspace files?
Try to downlaod them from CVS again, then check if lines in .vcw/.vcp
files are ended with CR/LF.
If it still is not working, give me ASAP a note I'll try to find where
it the problem.
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
