[Gdal-dev] RE: GDAL for windows CE
Norman Vine nhv at cape.com
Tue May 2 06:15:28 EDT 2006
Vasku Pech writes:
> I cannot by any means connect to your CVS server. When I try entering the password it gives me the following reply:
> Unknown host cvs.maptools.org
> I have fllowed the procedure described on www.gdal.org. This is what it says:
>  The GDAL source is available by anonymous CVS from the
> cvs.maptools.org server:
> % export
> CVSROOT=:pserver:cvsanon at cvs.maptools.org:/cvs/maptools/cvsroot
> % cvs login
> Password: *enter*
> % cvs checkout gdal
> Update access to the CVS repository can be obtained by
> arrangement with the maintainer.
Vasku
This is most likely an "English" language keyboard problem
When CVS asks you for a password DO *NOT* type "enter"
instead just hit the "Enter Key" < sometimes call *Return" >
eg  it is a BLANK password
HTH
Norman
