[Gdal-dev] Compiler errors in 1.3.2 on windows
Sun May 7 12:09:40 EDT 2006
Joaquim Luis wrote:
> Hi,
> When compiling on windows (VC6) I got the following errors.
> Removing the offending repeated 'int i' declarations solved the problem.
> Joaquim Luis
>        cl /nologo /MD /EHsc /Ox -I..\..\port -I..\..\ogr -I..\..\gcore
> -I..\..
> \alg -D_USE_MATH_DEFINES /c idrisiDataset.cpp
> idrisiDataset.cpp
> idrisiDataset.cpp(825) : error C2374: 'i' : redefinition; multiple
> initialization
Joaquim,
Sorry about this.  I haven't been so diligent in testing VC6 compatibility
lately.  I have fixed this in CVS.  You can replace the existing
IdrisiDataset.cpp with this file:
   http://www.gdal.org/srctree/frmts/idrisi/IdrisiDataset.cpp
I also ran into problems with ODBC support with 1.3.2 and my relatively
unpatched VC6 and had to updated port/cpl_odbc.cpp.
   http://www.gdal.org/srctree/port/cpl_odbc.h
Pressure mounts for a rapid 1.3.2.1 (or 1.3.3) release!
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
