[Gdal-dev] Compiler errors in 1.3.2 on windows
Joaquim Luis jluis at ualg.pt
Sun May 7 13:24:31 EDT 2006
Frank,
Thanks.
I built GDAL with ECW & MrSID support and as far as gdalinfo respects
things seams to be ok.
But now I want to integrate this options in my Matlab code and have a
question about these formats
that I never used before (well I ocasionally loaded MrSID and ECW files
with 3rth party softs).
Are they allways georeferenced or are they used for both "generic"
images and georeferenced images?
The thing is that depending on each case I need to treat it on different
sections of my code.
Thanks again
Joaquim Luis
> Joaquim,
> Sorry about this.  I haven't been so diligent in testing VC6
> compatibility
> lately.  I have fixed this in CVS.  You can replace the existing
> IdrisiDataset.cpp with this file:
>   http://www.gdal.org/srctree/frmts/idrisi/IdrisiDataset.cpp
> I also ran into problems with ODBC support with 1.3.2 and my relatively
> unpatched VC6 and had to updated port/cpl_odbc.cpp.
>   http://www.gdal.org/srctree/port/cpl_odbc.h
> Pressure mounts for a rapid 1.3.2.1 (or 1.3.3) release!
> Best regards,
