[Gdal-dev] adding lines and polygons in gdal-1.3.2
humarco
marco.hugentobler at karto.baug.ethz.ch
Wed May 10 07:46:35 EDT 2006
Dear gdal devs,
I have a problem with gdal-1.3.2 when adding lines and polygons to (shapefile)
layers. When i try to add lines to a line layer, ogr crashes. With polygons
no crash happens, but the polygons are not writen to the layer. It works ok
for points. And it also used to work with gdal-1.2.6 (the last version i
upgraded from). Is this a bug or false usage from me?
The crash happens another part of the code, so there may be a memory problem.
The platform i'm using is ubuntu linux, breezy badger. The code to add
features looks like this:
if(ogrLayer->CreateFeature(feature)!=OGRERR_NONE)
QgsLogger::warning("Writing of the feature failed");
returnValue = false;
++numberFeatures;
delete feature;
ogrLayer->SyncToDisk();
thanks,
Marco
