[Gdal-dev] ogr find neighbours
Didrik Pinte dpinte at itae.be
Wed May 10 10:49:58 EDT 2006
Le mercredi 10 mai 2006 à 10:26 -0400, Frank Warmerdam a écrit :
> Didrik,
> I would suggest only using Touches() and Overlaps() on polygons whose extent
> overlaps.  Touches() and Overlaps() are very expensive.
Looking at the profiling of the code, I understand your suggestion ;-)
> In fact, you might want to install a spatial filter with a box slightly
> larger than your polygon.  Then if you build a spatial index for your
> shapefile you will only have to read and examine a very small number of
> polygons assuming your polygons aren't too extreme.
What do you mean exactly by a spatial filter ? Just creating a buffer
around the bbox of each polygon ?
Here is a screen capture of the polygons i'm working on :
http://itae.be/downloads/dataset.png
Is there a way with ogr in Python to take into account a .shx file ?
Didrik
