[Gdal-dev] swig java: c/c++
Thu May 11 14:28:39 EDT 2006
Christine Spietz wrote:
> The problem:
> If I go into the swig/java directoty and call 'make build' there is the
> first error:
> [ GNUmakefile:3 ../../GDALmake.opt: No such file or directory ]
> => So I changed in swig/java/GNUmakefile the first include from
> 'GDALmake.opt' to 'GDALmake.opt.in'. This will solve this problem.
Christine,
A more appropriate solution is to run configure to make the GDALmake.opt
file from GDALmake.opt.in.
> Then again I call 'make build' and the next error occurs:
> swig -Wall -I../inculde -I ../include/java -outdir "org/gdal/gdal"
> -package "org.gdal.gdal" -[@abs_top_builddir -c++ -java -o gdal_wrap.cpp
> gdal.i
> ... /bin/sh: swig: command not found
> make: *** [gdal_wrap.cpp] Error 127
You will need to have SWIG installed to generate the bindings.  I believe
a very recent version is required though I'm not sure exactly what version
that is.
   http://www.swig.org/
I'm afraid building the java bindings is likely to be complicated.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
