[Gdal-dev] GDAL on 64-bit Windows?
Simon Perkins
sy at perkins.net
Mon May 15 19:13:06 EDT 2006
Has anyone successfully compiled GDAL on 64-bit windows (in 64-bit
mode). I'm using Visual Studio 2005, with the command line tools enabled
using the "x86_amd64" option, which uses the 32-bit compiler to create
64-bit executables and libraries. With GDAL 1.3.2:
> nmake /f makefile.vc
C:\cygwin\home\154712\src\gdal-1.3.2\frmts>cd pcraster && nmake
/NOLOGO /f mak
efile.vc && cd ..
cl /nologo /MD /EHsc /Ox -I..\..\port -I..\..\ogr -I..\..\gcore
-I..\..
\alg -Ilibcsf /c pcrasterdataset.cpp
pcrasterdataset.cpp
c:\cygwin\home\154712\src\gdal-1.3.2\frmts\pcraster\libcsf\csftypes.h(383)
: fat
al error C1189: #error : BYTE ORDER NOT SPECIFIED (CPU_LITTLE_ENDIAN or
CPU_BIG
_ENDIAN)
NMAKE : fatal error U1077: '"c:\Program Files (x86)\Microsoft Visual
Studio 8\VC
\BIN\x86_amd64\cl.EXE"' : return code '0x2'
Stop.
C:\cygwin\home\154712\src\gdal-1.3.2\frmts\pcraster>cd leveller &&
nmake /NOLO
GO /f makefile.vc && cd ..
The system cannot find the path specified.
C:\cygwin\home\154712\src\gdal-1.3.2\frmts\pcraster>cd sgi && nmake
/NOLOGO /f
C:\cygwin\home\154712\src\gdal-1.3.2\frmts\pcraster>cd idrisi && nmake
/NOLOGO
C:\cygwin\home\154712\src\gdal-1.3.2\frmts\pcraster>cd jpeg && nmake
/NOLOGO /
C:\cygwin\home\154712\src\gdal-1.3.2\frmts\pcraster>cd bsb && nmake
/NOLOGO /f
C:\cygwin\home\154712\src\gdal-1.3.2\frmts\pcraster>cd zlib && nmake
/NOLOGO /
NMAKE : fatal error U1077: 'for' : return code '0x1'
Stop.
Studio 8\VC
\BIN\nmake.EXE"' : return code '0x2'
Stop.
Any ideas?
Cheers,
Sy
