[Gdal-dev] Re: GDAL on 64-bit Windows?
Simon Perkins sy at perkins.net
Tue May 16 12:17:46 EDT 2006
OK, fixed the first problem. The file frmts/pcraster/makefile.vc should
have the line:
EXTRAFLAGS =     -Ilibcsf -DUSE_IN_GDAL
Rather than:
Without this definition the csftypes.h file doesn't define
CPU_LITTLE_ENDIAN as it is supposed to. A fallback catches things on
win32 but not on win64...
I'll check in an update later today.
I now get all the formats built, but then fail at the final link of the
GDAL library with some missing symbols:
 > nmake /f makefile.vc
        link /dll /debug /INCLUDE:_OGRFeatureStylePuller
/INCLUDE:_OSRValidate  /INCLUDE:_OPTGetProjectionMethods
/INCLUDE:_OGR_G_GetPointCount  /INCLUDE:_OGRRegisterAll
/INCLUDE:_GDALSimpleImageWarp at 36  /INCLUDE:_GDALReprojectImage at 48
/INCLUDE:_GDALComputeMedianCutPCT at 32  /INCLUDE:_GDALDitherRGB2PCT at 28
/INCLUDE:_vbSafeArrayToPtr at 16
/INCLUDE:_OCTNewCoordinateTransformation at 8 port\*.obj gcore\*.obj
alg\*.obj frmts\o\*.obj ogr\ogrsf_frmts\ogrsf_frmts.lib ogr\ogr.lib
vb6\vb6_support.obj      odbc32.lib
gcore\Version.res  /out:gdal13.dll /implib:gdal_i.lib
Microsoft (R) Incremental Linker Version 8.00.50727.42
Copyright (C) Microsoft Corporation.  All rights reserved.
   Creating library gdal_i.lib and object gdal_i.exp
LINK : error LNK2001: unresolved external symbol
LINK : error LNK2001: unresolved external symbol _vbSafeArrayToPtr at 16
LINK : error LNK2001: unresolved external symbol _GDALDitherRGB2PCT at 28
LINK : error LNK2001: unresolved external symbol _GDALComputeMedianCutPCT at 32
LINK : error LNK2001: unresolved external symbol _GDALReprojectImage at 48
LINK : error LNK2001: unresolved external symbol _GDALSimpleImageWarp at 36
LINK : error LNK2001: unresolved external symbol _OGRRegisterAll
LINK : error LNK2001: unresolved external symbol _OGR_G_GetPointCount
LINK : error LNK2001: unresolved external symbol _OPTGetProjectionMethods
LINK : error LNK2001: unresolved external symbol _OSRValidate
LINK : error LNK2001: unresolved external symbol _OGRFeatureStylePuller
gdal13.dll : fatal error LNK1120: 11 unresolved externals
NMAKE : fatal error U1077: '"c:\Program Files (x86)\Microsoft Visual
Studio 8\VC\BIN\x86_amd64\link.EXE"' : return code '0x460'
Stop.
So, the linker is not finding the additional symbols that are added to
the link line via /INCLUDE flags. Perhaps these symbols have different
names on x64? Why are these extra symbols addded? How would I find out
what their equivalents are for x64? Is there some equivalent for "nm" to
dump library symbols on windows?
Has nobody out there tried a 64-bit windows compile yet? Surely I'm not
the first! :)
Cheers,
Sy
Simon Perkins wrote:
> Hi,
> Has anyone successfully compiled GDAL on 64-bit windows (in 64-bit
> mode). I'm using Visual Studio 2005, with the command line tools
> enabled using the "x86_amd64" option, which uses the 32-bit compiler
> to create 64-bit executables and libraries. With GDAL 1.3.2:
> C:\cygwin\home\154712\src\gdal-1.3.2\frmts>cd pcraster   && nmake
> /NOLOGO /f mak
> efile.vc   && cd ..
>        cl /nologo /MD /EHsc /Ox -I..\..\port -I..\..\ogr
> -I..\..\gcore  -I..\..
> \alg -Ilibcsf /c pcrasterdataset.cpp
> pcrasterdataset.cpp
> c:\cygwin\home\154712\src\gdal-1.3.2\frmts\pcraster\libcsf\csftypes.h(383)
> : fat
> al error C1189: #error :  BYTE ORDER NOT SPECIFIED (CPU_LITTLE_ENDIAN
> or CPU_BIG
> _ENDIAN)
> Studio 8\VC
> \BIN\x86_amd64\cl.EXE"' : return code '0x2'
> Stop.
> C:\cygwin\home\154712\src\gdal-1.3.2\frmts\pcraster>cd leveller   &&
> nmake /NOLO
> GO /f makefile.vc   && cd ..
> The system cannot find the path specified.
> C:\cygwin\home\154712\src\gdal-1.3.2\frmts\pcraster>cd sgi   && nmake
> /NOLOGO /f
> C:\cygwin\home\154712\src\gdal-1.3.2\frmts\pcraster>cd idrisi   &&
> nmake /NOLOGO
> C:\cygwin\home\154712\src\gdal-1.3.2\frmts\pcraster>cd jpeg   && nmake
> /NOLOGO /
> C:\cygwin\home\154712\src\gdal-1.3.2\frmts\pcraster>cd bsb   && nmake
> /NOLOGO /f
> C:\cygwin\home\154712\src\gdal-1.3.2\frmts\pcraster>cd zlib   && nmake
> /NOLOGO /
> NMAKE : fatal error U1077: 'for' : return code '0x1'
> Stop.
> Studio 8\VC
> \BIN\nmake.EXE"' : return code '0x2'
> Stop.
> Any ideas?
> Cheers,
> Sy
