[Gdal-dev] Re: ruby bindings not compiling from CVS
Ken-ichi Ueda
kueda at nature.berkeley.edu
Fri May 19 03:06:32 EDT 2006
I lost track of this conversation when it started getting into the
guts of SWIG and the GDAL compilation process. What's the current
status of this problem? I just tried to download and compile the
daily CVS version and experienced exactly the same issue. Has a bug
been filed? Anyone know if this is likely to get fixed any time
soon? Is there anything I can do as someone who knows nothing about
C or SWIG?
-Ken-ichi
On May 2, 2006, at 10:45 AM, Charlie Savage wrote:
> Don't have a Mac. I'll try to take a look at windows and linux,
> maybe the problem occurs there also.
> Charlie
> Ken-ichi wrote:
>> No, no errors during the compilation, and no mention of 'ruby'
>> whatsoever during the same. I take it you are unable to reproduce
>> this problem?
>> Ken-ichi Ueda
>> Kelly Research and Outreach Lab (http://kellylab.berkeley.edu)
>> University of California, Berkeley
>> Environmental Science, Policy, and Management
>> Berkeley, CA 94720
>> tel: 510.642.8322
>> fax: 510.642.1477
>> e-mail: kueda at nature.berkeley.edu
>>> Any error messages in the compiling stage?
>>> Charlie
>>> Ken-ichi wrote:
>>>> Hi Charlie,
>>>> Nope, the extension never gets built. The only things in swig/
>>>> ruby are the sources and makefiles.
>>>> Ken-ichi Ueda
>>>> Berkeley, CA 94720
>>>> tel: 510.642.8322
>>>> fax: 510.642.1477
>>>>> Hi Ken-ichi,
>>>>> Is the extension successfully built? IE., is there a gdal.so
>>>>> file in the swig/ruby directory?
>>>>> Charlie
>>>>> Ken-ichi wrote:
>>>>>> Hi all,
>>>>>> When I try to compile the latest CVS (4.30.06) version of GDAL
>>>>>> --with-ruby, configuring and compiling go off without a hitch,
>>>>>> but when I try to make install, I get this error:
>>>>>> (cd swig; make install)
>>>>>> for dir in ruby ; do (cd $dir; make install ); done
>>>>>> make -f RubyMakefile.mk install
>>>>>> /bin/sh /usr/local/src/gdal-cvs-2006.04.30/libtool --
>>>>>> mode=install /usr/local/src/gdal-cvs-2006.04.30/install-sh -c
>>>>>> gdal.so ogr.so gdalconst.so osr.so /usr/darwinports/lib/ruby/
>>>>>> site_ruby/1.8/powerpc-darwin8.6.0/gdal
>>>>>> /usr/local/src/gdal-cvs-2006.04.30/install-sh -c gdal.so /usr/
>>>>>> darwinports/lib/ruby/site_ruby/1.8/powerpc-darwin8.6.0/gdal/
>>>>>> gdal.so
>>>>>> install: gdal.so does not exist
>>>>>> make[3]: *** [install] Error 1
>>>>>> make[2]: *** [install] Error 2
>>>>>> make[1]: *** [install] Error 2
>>>>>> make: *** [install-actions] Error 2
>>>>>> It doesn't look like gdal.so is getting made at all. I'm
>>>>>> getting basically the same error on Mac OS 10.4 and Gentoo
>>>>>> Linux. I do not get this error on Gentoo with the 1.3.1
>>>>>> source (haven't tried that one on my Mac yet).
>>>>>> Any thoughts?
