[Gdal-dev] Re: ruby bindings not compiling from CVS
Ari Jolma ari.jolma at tkk.fi
Wed May 3 05:36:31 EDT 2006
Howard Butler kirjoitti:
> At 01:21 PM 5/2/2006, Charlie Savage wrote:
>> The error on the build box is that the -autorename SWIG switch is in
>> SWIG 1.3.28 and higher.
>> Thought Ari upgraded Perl to use SWIG 1.3.29?  The current CVS ruby
>> swig wrapper cxx files are from 1.3.28 if I remember correctly.  Any
>> reason not to use those as opposed to generating new ones when building?
> That's the build farm for GDAL until we can get things moved to
> TelaScience.  I thought it would be prudent to force complete building
> of everything to fully see the impact of changes.
make generate does not force regeneration of wrappers at least in the
Perl case -- that's because I've uploaded recent copies to CVS. Yes, I'm
now using swig 1.3.29 but I'm not sure if 28 would work. I believe the
requirement should be put somewhere and explicitly fail if it is not
satisfied - such practice is common and good. ... ok, I'm just lecturing
here and not practising it myself to much...
Ari
Whether or not to use
> the latest and greatest SWIG is an issue though.
>> What were the changes in the makefiles that might cause issues?
> Andrey made some changes to remove the GDAL_ROOT variable and point
> directly to the GDALMake.opt file.  I know a couple of makefiles in the
> swig directory were missed, and I updated them, but I may have screwed
> something else up in the process.
> Howard
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
Prof. Ari Jolma
Kartografia ja Geoinformatiikka / Cartography and Geoinformatics
Teknillinen Korkeakoulu / Helsinki University of Technology
tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
