[Gdal-dev] can not perform "gdal_merge.py", "gdal_rgb2pct.py"
and "pct2rgb.py"
Mateusz Loskot
mateusz at loskot.net
Tue May 23 10:42:35 EDT 2006
Zhonghai Wang wrote:
> Hi guys,
> to solve my last problem I am trying to merge all the GIFs into one
> large TIF file usding the command gdal_merge.py, but the error
> message says that no such a command can be found, [...]
Do you use Unix/Linux?
Have you built GDAL from sources or installed form packages?
I use Ubuntu 5.10 (Debian) and gdal_merge.py script is available from
package 'python-gdal'.
What do you get from:
$ which gdal_merge.py
or
$ locate gdal_merge.py
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
