[Gdal-dev] installing gdal
    Mateusz Loskot
    mateusz at loskot.net
    Tue May 23 11:41:44 EDT 2006
Christine Spietz wrote:
> Hi Mateuz,
> yes I tried (wrote it in my first message) but this also doesn't help.
> First things I've tried can be found at the start of the thread
> (http://lists.maptools.org/pipermail/gdal-dev/2006-May/008925.html) and
> after nobody of the list had any ideas or hadn't the time to respond  I
> tried several other things (described in the last message
> http://lists.maptools.org/pipermail/gdal-dev/2006-May/008975.html) but
> they also didn't succeed.
Unfortunately, I'm completely not an expert of Java + SWIG
but I'd suggest you to try to build GDAL without any Java related
options first and see if it works.
Cheers
Mateusz Łoskot
http://mateusz.loskot.net
