[Gdal-dev] installing gdal
Christine Spietz
spietz at fh-bingen.de
Tue May 23 11:54:55 EDT 2006
Hi Mateuz,
yes thats it: I'm trying now to build GDAL.
I wanted to build Java and SWIG but then I realized that I had problems with
it because I actually was not able to build GDAL correctly.
And there I'm : no GDAL installed and therefore no chance to do anything
with gdal/ogr.
Christine
----- Original Message -----
To: <gdal-dev at lists.maptools.org>
Sent: Tuesday, May 23, 2006 5:41 PM
Subject: Re: [Gdal-dev] installing gdal
> Christine Spietz wrote:
>> Hi Mateuz,
>> yes I tried (wrote it in my first message) but this also doesn't help.
>> First things I've tried can be found at the start of the thread
>> (http://lists.maptools.org/pipermail/gdal-dev/2006-May/008925.html) and
>> after nobody of the list had any ideas or hadn't the time to respond I
>> tried several other things (described in the last message
>> http://lists.maptools.org/pipermail/gdal-dev/2006-May/008975.html) but
>> they also didn't succeed.
> Unfortunately, I'm completely not an expert of Java + SWIG
> but I'd suggest you to try to build GDAL without any Java related
> options first and see if it works.
> Cheers
> Mateusz Łoskot
> http://mateusz.loskot.net
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
