[Gdal-dev] installing gdal
Patton, Eric
epatton at nrcan.gc.ca
Wed May 24 14:16:27 EDT 2006
Ok, I managed to get gdal installed after I disabled libtool during
configure:
./configure --with-png=internal --with-jpeg=internal --with-gif=internal
--with-libtiff=internal --with-geotiff=internal --with-libz=internal
--without-pg --without-ogdi --with-python --with-threads=yes --with-sqlite
--without-grass --without-libgrass --enable-shared --without-libtool
I then did make and make install, no errors whatsoever.
I checked my installation with gdal_translate:
/usr/local/gdal-1.3.2$ gdal_translate --formats
Supported Formats:
Segmentation fault
Any ideas what happened here? I thought I had a clean installation there for
a second.
~ Eric.
-----Original Message-----
To: Patton, Eric
Sent: 5/24/2006 9:04 AM
Subject: Re: [Gdal-dev] installing gdal
Hi Eric,
I'm not realy familiar with c++ so I actually don't know what this
package
should do and I don't know Ubuntu.
But perhaos the following things will help:
I Looked at my system and I have
- compst-libstdc++5.0.7
- libstdc++4.0.2_20050901
- libstdc++-devel4.0.2_20050901
installed.
1) What commands did you make? Only unzip/untar and './configure' and
'make'
in GDAL-Home or anything else?
2) Is there a file 'libstdc++.la' in your /usr/lib ?
Christine
----- Original Message -----
To: "'Christine Spietz '" <spietz at fh-bingen.de>
Cc: <gdal-dev at lists.maptools.org>
Sent: Wednesday, May 24, 2006 2:44 PM
Subject: RE: [Gdal-dev] installing gdal
> Interesting, Christine, I'm getting complaints from make about
> libstdc++.la
> not being a valid libtool archive, but I've got every dev package I
could
> find in Ubuntu Synaptic installed, so I'm not sure what else I need.
> ~ Eric.
> From: gdal-dev-bounces at lists.maptools.org
> To: Christine Spietz
> Cc: gdal-dev at lists.maptools.org
> Sent: 5/24/2006 8:16 AM
> Me again,
> so finally I did it:
> My steps for installing gdal:
> 1) download gdal1.3.2.tar.gz
> 2) unzip/untar at /usr/lib/gdal => /usr/lib/gdal/gdal-1.3.2 =
GDAL-Home
> 3) ./configure
> 4) make
> error messages like
>>/usr/bin/sed: can't read /usr/lib/libjpg.la: No such file or directory
>>libtool: link: '/usr/lib/libjpg.la' is not a valid libtool archive
>>make[1]: *** [libgdal.la] Error 1
> make sense if you know what actually they mean... (Thanks to Nicol!)
> I had to install the missing packages
> - libjpeg-devel and
> - libpng-devel
> curious:
> even as I configures --with_jpeg=no I got the error that libjpg.la is
> not
> fount. So it seems taht these two packages are needed anyway to
install
> gdal
> regards,
> Christine
> From: "Christine Spietz" <spietz at fh-bingen.de>
> To: "Mateusz Loskot" <mateusz at loskot.net>
> Sent: Tuesday, May 23, 2006 5:54 PM
>> Hi Mateuz,
>> yes thats it: I'm trying now to build GDAL.
>> I wanted to build Java and SWIG but then I realized that I had
> problems
>> with it because I actually was not able to build GDAL correctly.
>> And there I'm : no GDAL installed and therefore no chance to do
> anything
>> with gdal/ogr.
>> Christine
>> From: "Mateusz Loskot" <mateusz at loskot.net>
>> To: <gdal-dev at lists.maptools.org>
>> Sent: Tuesday, May 23, 2006 5:41 PM
>>> Christine Spietz wrote:
>>>> Hi Mateuz,
>>>> yes I tried (wrote it in my first message) but this also doesn't
> help.
>>>> First things I've tried can be found at the start of the thread
>>>> (http://lists.maptools.org/pipermail/gdal-dev/2006-May/008925.html)
> and
>>>> after nobody of the list had any ideas or hadn't the time to
respond
> I
>>>> tried several other things (described in the last message
>>>> http://lists.maptools.org/pipermail/gdal-dev/2006-May/008975.html)
> but
>>>> they also didn't succeed.
>>> Unfortunately, I'm completely not an expert of Java + SWIG
>>> but I'd suggest you to try to build GDAL without any Java related
>>> options first and see if it works.
>>> Cheers
>>> Mateusz Loskot
>>> http://mateusz.loskot.net
>>> Gdal-dev mailing list
>>> Gdal-dev at lists.maptools.org
>>> http://lists.maptools.org/mailman/listinfo/gdal-dev
