[Gdal-dev] KML Write-only driver for OGR
Frank Warmerdam
warmerdam at pobox.com
Wed May 24 17:47:46 EDT 2006
Folks,
Christopher Condit wrote:
> Hi Frank-
> I know this is unsolicited, but I added this for my own use and I know
> there’s been some discussion on the mailing list about KML. If it’s
> useful to the community and you’re interested in adding it to OGR,
> please do.
> I’m attaching the source (and modifications to main files) for an OGR
> driver that outputs KML. Since KML is so close to GML, I just modified
> the GML driver and removed read support since it doesn’t make much sense
> to read a KML file. The source could probably be cleaner since I don’t
> really know OGR at all. But it works well for writing and does not
> require Xerces.
> I’d be happy to put in time to support this driver.
> Thanks for all your hard work on GDAL – it’s a great tool!
> -Chris
It occurs to me that I shouldn't really be making the decision to
incorporate this on my own. So I'm calling for a vote on this inclusion.
As I see it the downside is that this driver is write-only, which isn't
a concept that is particularly well handled by OGR (there is not way for
a driver to indicate it is write only currently). However, we have done
this for GML, and DWG/DXF in the past so it isn't a new thing.
Beyond that I (well actually Mateusz on my behalf) and Christopher would
be responsible for supporting the driver. Furthermore, we would incorporate
a simple test script into the gdalautotest for it.
So, I'll start things out with a +1 in support of this new driver.
PS. I don't foresee needing a written RFC for non-disruptive changes such
as adding a new driver.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
