[Gdal-dev] Building DLL's on Windows
Ari Jolma
ari.jolma at tkk.fi
Tue May 30 01:26:25 EDT 2006
Frank Warmerdam kirjoitti:
> Ari,
> My suggestion would be to use VC++ or MINGW to build your DLL. Cygwin's
> gcc includes funky dependencies on a cygwin DLL that *might* not play well
> with non-cygwin components.
libral uses variable length macros, which is AFAIK not in VC++, so MINGW
is the 2nd choice then. I looked at it and installed it but the docs did
not look very good for developing DLL's. Is there somewhere a simple
example (a Makefile or something) of creating a DLL with MinGW?
Thanks
Ari
> You may need a customized approach to configuration instead of using
> configure, or you may be able to use cygwin configuration with mingw with
> appropriate configurations.
> Best regards,
Prof. Ari Jolma
Kartografia ja Geoinformatiikka / Cartography and Geoinformatics
Teknillinen Korkeakoulu / Helsinki University of Technology
tel: +358 9 451 3886 address: POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
