[Gdal-dev] Envisat Meris GCPs bad georeferencement...
Frank Warmerdam
warmerdam at pobox.com
Tue May 30 11:43:17 EDT 2006
Stéphane COLZY wrote:
> Hi,
> I’d like to display Meris products in a Mapserver map but i can’t get
> the image to be well projected and scaled.
> The image appears on the map but its extents are far out bounds and its
> lower left corner is always docked to the map center.
> The destination map is in projection epsg:4326
> Here’s the info on an image I’m using:
Stephane,
MapServer does not support using GCPs from a GDAL image. You will likely
need to use gdalwarp to rectify the image before you can use it with
mapserver.
Best regards,
and watch the world go round - Rush | President OSGF, http://osgeo.org
