[Gdal-dev] Envisat Meris GCPs bad georeferencement...
Stéphane COLZY
stephane.colzy at magellium.fr
Tue May 30 09:59:26 EDT 2006
Id like to display Meris products in a Mapserver map but i cant get the
image to be well projected and scaled.
The image appears on the map but its extents are far out bounds and its
lower left corner is always docked to the map center.
The destination map is in projection epsg:4326
Heres the info on an image Im using:
Driver: GTiff/GeoTIFF
Size is 2241, 2241
Coordinate System is `'
GCP Projection = GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS
84",6378137,298.
2572235630016,AUTHORITY["EPSG","7030"]],AUTHORITY["EPSG","6326"]],PRIMEM["Gr
eenw
ich",0],UNIT["degree",0.0174532925199433],AUTHORITY["EPSG","4326"]]
GCP[ 0]: Id=1, Info=
(0,0) -> (1.39256,58.1008,0)
GCP[ 1]: Id=2, Info=
(560.25,0) -> (3.76845,57.7639,0)
GCP[ 2]: Id=3, Info=
(1120.5,0) -> (6.09777,57.3834,0)
GCP[ 3]: Id=4, Info=
(1680.75,0) -> (8.37677,56.9608,0)
GCP[ 4]: Id=5, Info=
(2241,0) -> (10.6024,56.4975,0)
GCP[ 5]: Id=6, Info=
(0,448.2) -> (0.869172,56.9542,0)
GCP[ 6]: Id=7, Info=
(560.25,448.2) -> (3.17538,56.6237,0)
GCP[ 7]: Id=8, Info=
(1120.5,448.2) -> (5.43918,56.2513,0)
GCP[ 8]: Id=9, Info=
(1680.75,448.2) -> (7.65714,55.8383,0)
GCP[ 9]: Id=10, Info=
(2241,448.2) -> (9.82645,55.3862,0)
GCP[ 10]: Id=11, Info=
(0,896.4) -> (0.370076,55.8061,0)
GCP[ 11]: Id=12, Info=
(560.25,896.4) -> (2.61121,55.4814,0)
GCP[ 12]: Id=13, Info=
(1120.5,896.4) -> (4.81357,55.1164,0)
GCP[ 13]: Id=14, Info=
(1680.75,896.4) -> (6.97408,54.7123,0)
GCP[ 14]: Id=15, Info=
(2241,896.4) -> (9.09013,54.2705,0)
GCP[ 15]: Id=16, Info=
(0,1344.6) -> (-0.107114,54.6566,0)
GCP[ 16]: Id=17, Info=
(560.25,1344.6) -> (2.07314,54.3372,0)
GCP[ 17]: Id=18, Info=
(1120.5,1344.6) -> (4.21788,53.979,0)
GCP[ 18]: Id=19, Info=
(1680.75,1344.6) -> (6.32427,53.5832,0)
GCP[ 19]: Id=20, Info=
(2241,1344.6) -> (8.38995,53.1511,0)
GCP[ 20]: Id=21, Info=
(0,1792.8) -> (-0.564501,53.5058,0)
GCP[ 21]: Id=22, Info=
(560.25,1792.8) -> (1.55875,53.1912,0)
GCP[ 22]: Id=23, Info=
(1120.5,1792.8) -> (3.64935,52.8393,0)
GCP[ 23]: Id=24, Info=
(1680.75,1792.8) -> (5.70476,52.4512,0)
GCP[ 24]: Id=25, Info=
(2241,1792.8) -> (7.72279,52.028,0)
GCP[ 25]: Id=26, Info=
(0,2241) -> (-1.00394,52.3539,0)
GCP[ 26]: Id=27, Info=
(560.25,2241) -> (1.06585,52.0436,0)
GCP[ 27]: Id=28, Info=
(1120.5,2241) -> (3.10558,51.6975,0)
GCP[ 28]: Id=29, Info=
(1680.75,2241) -> (5.11291,51.3165,0)
GCP[ 29]: Id=30, Info=
(2241,2241) -> (7.08585,50.9018,0)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_XRESOLUTION=1
TIFFTAG_YRESOLUTION=1
TIFFTAG_RESOLUTIONUNIT=1 (unitless)
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 2241.0)
Upper Right ( 2241.0, 0.0)
Lower Right ( 2241.0, 2241.0)
Center ( 1120.5, 1120.5)
Band 1 Block=2241x8 Type=Byte, ColorInterp=Red
Band 2 Block=2241x8 Type=Byte, ColorInterp=Green
Band 3 Block=2241x8 Type=Byte, ColorInterp=Blue
I just wonder if theres an option Im missing in Mapserver or if the image
info is simply flawed
Thank for help !
Stéphane COLZY
05 61 28 81 22
MAGELLIUM
10 avenue de l'Europe
31525 - Ramonville Saint Agne
http://www.magellium.fr <http://www.magellium.fr/>
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20060530/ab660823/attachment.html
