[Gdal-dev] performance issue with gdal_translate...
Wed May 31 15:34:09 EDT 2006
John Cole wrote:
> I'm creating a tiled geotif on a large jpg file
> gdal_translate -of GTiff -co "TILED=YES" madison_1f_01.jpg madison_1f_01.tif
> Input file size is 44400, 42600
> Gdal_translate is working, but it's really slow and only using 0.5% of
> memory (according to top).
>   PID USER      PR  NI  VIRT  RES  SHR S %CPU %MEM    TIME+  COMMAND
>  4350 root      25   0 65228  22m 6252 R  100  0.5   2:18.82 gdal_translate
> Since I have a decent system for this, I was wondering what --config
> switches I could use to speed this up?
> I'm running Fedora Core 5 on a dual xeon 3ghz with 4GB of memory.
John,
I think you want to force GDAL_CACHEMAX up.  When reformatting scanline
oriented file to tiles or tiles to scanlines it is important to have
a cache large enough to hold a whole row of tiles or performance degrades
seriously.
GDAL_CACHEMAX is normally a number of megabytes, and the default is 10 I
think.
So something like:
gdal_translate -of GTIFF -co TILED=YES --config GDAL_CACHEMAX 120 \
Would use a 120MB cache.
Best regards,
and watch the world go round - Rush    | President OSGF, http://osgeo.org
