[Gdal-dev] RFC 7: API Change for the VSIxxxL family
of file functions
Eric Dönges
eric.doenges at gmx.net
Wed Nov 1 06:10:37 EST 2006
Am 31.10.2006 um 16:32 schrieb Frank Warmerdam:
> VSIFOpenL() is not an across the board replacement for VSIFOpen().
> The non-L version of the functions continue to exist because
> some drivers use stdio functions that are not implemented for in
> the "L" api, such as VSIFGets(). In some cases driver code directly
> calls stdio functions using the FILE *.
I see. After looking at what VSIVirtualHandle provides, and what the
drivers
in frmts and ogr need, what seems to be missing is equivalent
functionality to fgets,
fgetc, ungetc, fprintf and fscanf. The first three would be fairly
trivial to add, but
the next two ...
> Agreed. One approach might be to make VSILFILE* a void pointer for
> now
> with the intention of making it something else that would trigger type
> checking failures later - perhaps when we switch to GDAL 2.0 and are
> willing to sacrifice some backwards compatibility anyways.
> In the meantime applications can upgrade to the new mechanisms without
> too much disruption.
I reluctantly agree. I've updated the RFC accordingly. The short-term
solution
should be much less work to do, since initially only two files need
to be changed
(cpl_vsil.cpp and cpl_vsi.h).
--- snip ---
RFC 7: API Change for the VSIxxxL family of file functions
Author: Eric Dönges
Contact: Eric.Doenges at gmx.net
Status: Proposed
Purpose
To change the API for the VSIxxxL family of functions to use a new
data-type
VSILFILE instead of the current FILE.
Background, Rationale
Currently, GDAL offers two APIs to abstract file access functions
(referred to
as VSIxxx and VSIxxxL in this document). Both APIs claim to operate
on FILE*;
however, the VSIxxxL functions can only operate on FILE* created by the
VSIOpenL function. This is because VSIOpenL returns a pointer to an
internal
C++ class typecast to FILE*, not an actual FILE*. This makes it
impossible
for the compiler to warn when the VSIxxx and VSIxxxL functions are
inappropriately mixed.
Proposed Fix
A new opaque data-type VSILFILE shall be declared. All VSIxxxL
functions shall
be changed to use this new type instead of FILE. Additionally, any
GDAL code
that uses the VSIxxxL functions must be changed to use this data-type
as well.
Compatibility Issues, Transition timeline
In order to allow the compiler to detect inappropriate parameters
passed to
any of the VSIxxxL functions, VSILFILE would have to be declared with
the help
of an empty forward declaration, i.e. "typedef struct VSILFILE
VSILFILE", with
the struct VSILFILE itself left undefined. However, this would break
source
compatibility for any existing code using the VSIxxxL API.
Therefore, VSILFILE* will be declared as a void pointer for now, and
the change
to a distinct pointer type deferred to a future release of gdal that
is not
constrained with backward compatibility issues. While this will not
solve the
primary issue (no warnings/errors from the compiler), looking at the
declarations
of the VSIxxxL functions will at least make it immediately clear that
these
functions cannot be expected to work if passed a FILE pointer.
--- snip ---
With kind regards,
Eric
