[Gdal-dev] gdal_merge.py
Dorita
izzybitsie at gmail.com
Thu Nov 2 17:05:40 EST 2006
I am trying to compose a couple of GeoTiff images into one GeoTiff image.
I run the command merge.py -o kk.tif -pct kk1.tif kk2.tif. Running doesn't
complain, but the final image only shows kk1.tif. I have tried to run
same command with different images with same results.
Both input files are in the same coordinate system and have one band.
The input images were downloaded from
http://www.hydro.gov.au/seafarer/geotiff/geotiff-sample/geotiff-sample.htm
for test purposes.
I am using gdal 1.3.2.0 , Python 2.4.2 and the system is 2.4.32-gentoo-r4
Tx
izzy
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061102/83918730/attachment.html
