[Gdal-dev] GDAL and Python
Howard Butler
hobu at iastate.edu
Thu Nov 2 17:07:46 EST 2006
At 03:45 PM 11/2/2006, Christopher Barker wrote:
>Is the plan for GDAL to depend on numpy? If so, then methods that
>return batches of data can return numpy arrays, which conform to
>the array interface, and could be used by other libs that understand
>that, so it's no big deal.
Is numpy "the winner" in the sense that numeric, numarray, etc have
fallen to the wayside as far as developer momentum and general
use? I don't follow these communities close enough to know. I think
going forward, GDAL only wants to support one array library, and the
array interface stuff looks like a great way to do it. As of right
now, there's nothing for the next-gen Python bindings, so if I'm able
to get a numpy interface going, that's probably as far as it would go
unless someone else steps in and develops something else.
>Aren't there going to be API changes anyway? editing import
>statements is a very minor task.
>>I don't know how we approach this other than to write and RFC, pass
>>it, and just do it.
>Nor do I. I say if you're writing the code, you have a lot of
>freedom to structure it the way you want.
The next-gen Python bindings are deliberately consistent with the
old-gen ones. API changes between the two are minimal to
non-existent. The biggest missing piece has been the
numpy/numeric/numarray support, which for lots of people is a very
key piece of missing functionality. I hope to close this gap.
As far as the imports and package structure, I agree its impact is
probably minimal, but some might find the churn annoying nonetheless.
Howard
