[Gdal-dev] GDAL and Python
Christopher Barker
Chris.Barker at noaa.gov
Thu Nov 2 18:30:54 EST 2006
Howard Butler wrote:
> Is numpy "the winner" in the sense that numeric, numarray, etc have
> fallen to the wayside as far as developer momentum and general use?
In terms of anything new, yes. Legacy projects will probably be using
Numeric or numarray for a while yet, but numpy is clearly the way to go
for anything new.
> I think going
> forward, GDAL only wants to support one array library, and the array
> interface stuff looks like a great way to do it.
Exactly. If you generate numpy arrays, then Numeric an numarray will be
able to work with them efficiently anyway.
> The next-gen Python bindings are deliberately consistent with the
> old-gen ones.
Well, that's probably a good thing.
> The biggest missing piece has been the numpy/numeric/numarray support,
> which for lots of people is a very key piece of missing functionality.
> I hope to close this gap.
I know it's a big gap for me.
> As far as the imports and package structure, I agree its impact is
> probably minimal, but some might find the churn annoying nonetheless.
I still say go for it!
Are you using SWIG? If so, be sure to check out:
http://www.scipy.org/Cookbook/SWIG_and_NumPy
Also, the numpy mailing list folks are very helpful:
https://lists.sourceforge.net/lists/listinfo/numpy-discussion
You'll be well served by getting on that list and asking questions.
-Chris
Christopher Barker, Ph.D.
Oceanographer
NOAA/OR&R/HAZMAT (206) 526-6959 voice
7600 Sand Point Way NE (206) 526-6329 fax
Seattle, WA 98115 (206) 526-6317 main reception
