[Gdal-dev] Extracting subimage in GDAL
Frank Warmerdam
warmerdam at pobox.com
Mon Nov 6 15:56:29 EST 2006
Ozy Sjahputera wrote:
> Greetings,
> I am new to GDAL so I apologize if this topic has been discussed
> before. I used Google to search for several key words -- like
> "subimage" -- in the list archives. The only one I found to be close is
> this: http://lists.maptools.org/pipermail/gdal-dev/2004-May/002776.html
> where Frank pointed out the use of GDAL utility gdal_translate() to
> extract sub-images.
> I need to extract subimage by specifying the new UL and LR coordinates
> (in UTM). I understand that gdal_translate with -projwin option can do
> this. However, I need to do this as a function call within a CPP
> program. Is there a function in GDAL library that is equivalent to the
> utility gdal_translate?
Ozy,
No. But if you know the source window in pixel/line coordinates you
can load it into a buffer with the GDALRasterBand::RasterIO() method
or the GDALDataset::RasterIO() method.
> Or where can I find the source code for
> gdal_translate if I want to learn more about how gdal_translate is
> implemented?
The gdal_translate source can be found in gdal/apps/gdal_translate.c
or on the web:
http://www.gdal.org/srctree/apps/gdal_translate.c
The pertinent portion for -projwin is:
/* Compute the source window from the projected source window */
/* if the projected coordinates were provided. Note that the */
/* projected coordinates are in ulx, uly, lrx, lry format, */
/* while the anSrcWin is xoff, yoff, xsize, ysize with the */
/* xoff,yoff being the ulx, uly in pixel/line. */
if( dfULX != 0.0 || dfULY != 0.0
|| dfLRX != 0.0 || dfLRY != 0.0 )
double adfGeoTransform[6];
GDALGetGeoTransform( hDataset, adfGeoTransform );
if( adfGeoTransform[2] != 0.0 || adfGeoTransform[4] != 0.0 )
fprintf( stderr,
"The -projwin option was used, but the geotransform is\n"
"rotated. This configuration is not supported.\n" );
GDALClose( hDataset );
CPLFree( panBandList );
GDALDestroyDriverManager();
exit( 1 );
anSrcWin[0] = (int)
((dfULX - adfGeoTransform[0]) / adfGeoTransform[1] + 0.001);
anSrcWin[1] = (int)
((dfULY - adfGeoTransform[3]) / adfGeoTransform[5] + 0.001);
anSrcWin[2] = (int) ((dfLRX - dfULX) / adfGeoTransform[1] + 0.5);
anSrcWin[3] = (int) ((dfLRY - dfULY) / adfGeoTransform[5] + 0.5);
if( !bQuiet )
fprintf( stdout,
"Computed -srcwin %d %d %d %d from projected window.\n",
anSrcWin[0],
anSrcWin[1],
anSrcWin[2],
anSrcWin[3] );
if( anSrcWin[0] < 0 || anSrcWin[1] < 0
|| anSrcWin[0] + anSrcWin[2] > GDALGetRasterXSize(hDataset)
|| anSrcWin[1] + anSrcWin[3] > GDALGetRasterYSize(hDataset) )
fprintf( stderr,
"Computed -srcwin falls outside raster size of %dx%d.\n",
GDALGetRasterXSize(hDataset),
GDALGetRasterYSize(hDataset) );
exit( 1 );
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
