[Gdal-dev] Installation problems: GDAL 1.3.2 on Fedora5 (64Bit)
Rainer Spittel
rainer.spittel at terralink.co.nz
Thu Nov 9 22:54:35 EST 2006
Hi Frank
Unfortunately I can not open a ssh port at the moment. :-( After
making the copy of the shared object from the lib64 to the lib folder,
ldconfig throws a warning:
ldconfig: libraries libidn.so.11 and libidn.so in directory /usr/lib
have same soname but different type.
Hmmm, this copy-solution seems to make trouble.
Now, I just tried to compile PHP and get a similar error message with
another library:
checking for fabsf... yes
checking for floorf... yes
configure: error: libjpeg.(a|so) not found.
The libjpeg.so is located in the /usr/lib64 folder :-(
Cheers
Rainer
P.S.: By the way, it's a Fedora 5, not Ubuntu system.
-----Original Message-----
From: Frank Warmerdam [mailto:warmerdam at pobox.com]
Sent: Friday, 10 November 2006 4:48 p.m.
To: Rainer Spittel
Cc: gdal-dev at lists.maptools.org
Subject: Re: [Gdal-dev] Installation problems: GDAL 1.3.2 on Fedora5
(64Bit)
Rainer Spittel wrote:
> Hi
> Some weeks ago I tried to compile GDAL 1.3.2 on Fedora 5 32Bit and
> had
> some compiling errors. I got the advise to take the CVS version. That
> helped a lot and the compiling process went through without any
problems.
> Now I try to update the server, installing the same GDAL environment
> on a Fedora 5 64Bit OS and have compiling errors again. GDAL can not
> locate the libidn.so in /usr/lib. This library is in /usr/lib64.
> What I tried if to copy the libidn.so file from the /usr/lib64 to
> the
> /usr/lib folder. It works - but I don't like it! ;-) This is a very
> scary approach to solve those problems.
Rainer,
If you can provide temporary ssh access to such a system, I could look
into the problem. I am not aware of any problems on my 64bit ubuntu
system.
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
and watch the world go round - Rush | President OSGeo,
http://osgeo.org
