[Gdal-dev] Create Images with GDAL in C#
Tamas Szekeres szekerest at gmail.com
Mon Nov 13 17:34:59 EST 2006
I've tested the following code with success:
public static void Main(string[] args)
          create(args[0]);
public static void create(string file)
        Driver dv;
        Dataset ds;
        Band ba;
        int bXSize, bYSize;
        int w, h;
        string [] options;
        w = 100;
        h = 100;
        bXSize = w;
        bYSize = 1;
        gdal.AllRegister();
        dv = gdal.GetDriverByName("GTiff");
        options = new string [] {"BLOCKXSIZE=" + bXSize, "BLOCKYSIZE="
+ bYSize};
        ds = dv.Create(file, w, h, 1, gdalconst.GDT_Byte, options);
        ba = ds.GetRasterBand(1);
        float [] buffer;
        buffer = new float [w * h];
        for (int i = 0; i < buffer.Length; i++)
            buffer[i] = i*256/buffer.Length;
        ba.WriteRaster(0, 0, w, h, buffer, w, h, 0, 0);
        ba.FlushCache();
        ds.FlushCache();
        ba.Dispose();
        ds.Dispose();
Are you using the latest CVS version?
Best Regards,
Tamas Szekeres
2006/11/13, Jean Michel PIERRET <jmp at geosys.com>:
> Hi,
> I've just tried to use the GDAL C#, it's ok to read images,
> But i have problem to create images, all my created images are empty.
> Driver dv;
>       Dataset ds;
>       Band ba;
>       int bXSize, bYSize;
>       int w, h;
>       string [] options;
>       w = 100;
>       h = 100;
>       bXSize = w;
>       bYSize = 1;
>       options = new string [] {"BLOCKXSIZE=" + bXSize, "BLOCKYSIZE=" +
> bYSize};
>       ds = dv.Create(file, w, h, 1, gdalconst.GDT_Float32, options);
>       float [] buffer;
>             buffer[i] = i;
>       b.WriteRaster(0, 0, w, h, buffer, w, h, 0, 0);
>       b.FlushCache();
>       d.FlushCache();
>       b.Dispose();
>       d.Dispose();
> Thanks for your help and all your work on c# bindings.
> PIERRET Jean michel.
> Gdal-dev mailing list
> Gdal-dev at lists.maptools.org
> http://lists.maptools.org/mailman/listinfo/gdal-dev
