[Gdal-dev] Re: Problem : Building GDAL for windows CE
Mateusz Loskot
mateusz at loskot.net
Tue Nov 14 07:53:38 EST 2006
kiruba,
Please, give me a day till tomorrow night (Wednesday)
I'm on my way to investigate it in details.
I appologize to for the delay.
Cheers
Mateusz
kiruba nantham wrote:
> Hello Mr. Mateusz,
> I am sorry to disturb you again and again, when you are busy.
> Now I am building *gdal-cvs-2006.11.13 *I have copied all
> the required headers and libraries to gdal-cvs-2006.11.13* *folder. Then
> I started to build *gdal-cvs-2006.11.13 *from* *command prompt but now
> it’s throwing this error *fatal error LNK1112: module machine type ‘X86’
> conflicts with target machine type ‘ARM’*.
> If I build *gdal-cvs-2006.11.13 (*evc4_gdalce_dll.vcw
> workspace*)* using EVC++ 4.0. I am getting *gdalce_evc4.dll* but when I
> am building *gdal-cvs-2006.11.13 *source I am getting 130 warnings
> Warnings are:
> Warning C4530: C++ exception handler used, but unwind semantics are not
> enabled. Specify –GX.
> Warning C4275: non dll-interface class 'std::basic_string<char,struct
> std::char_traits<char>, class
> std::allocator<char> >' used as
> base for dll-interface class 'CPLString'.
> These two warnings are repeating and
> Linker Warnings are:
> mitab_feature.obj: warning LNK1166: cannot adjust code at
> offset=0x00001000, rva=0x0001C7DC.
> mitab_feature_mif.obj: warning LNK1166: cannot adjust code at
> offset=0x00001000, rva=0x000326C0
> ogr_srs_proj4.obj: warning LNK1166: cannot adjust code at
> offset=0x00001000, rva=0x000947D0
> ogrspatialreference.obj: warning LNK1166: cannot adjust code at
> offset=0x00001000, rva=0x000C5794
> And also when it is connecting to emulator it’s prompting this
> error (The intel 80486 CPU does not support configuration
> evc4_gdalce_dll-Win32 (WCE ARMV4) Debug! Executable will not run on
> device. Continue?) If I give OK to continue it is building this
> *gdalce_evc4.dll *but it is of no use. Please can you tell me how to
> solve this?
> Thank you,
> Kirubanantham.K.
> Everyone is raving about the all-new Yahoo! Mail beta.
> <http://us.rd.yahoo.com/evt=45083/*http://advision.webevents.yahoo.com/mailbeta>
Mateusz Loskot
http://mateusz.loskot.net
