[Gdal-dev] GeoQuadTree - an open format for storing
georeferencedimages
Brent Fraser
bfraser at geoanalytic.com
Tue Nov 14 15:05:23 EST 2006
For those interested tiling,
There is similar tiling related discussion/work going on at:
http://lists.eogeo.org/mailman/listinfo/tiling (do they have a web page?)
and
http://www.stereofx.org/terrain.html, implemented in http://vterrain.org/, particularly VTBuilder (http://vterrain.org/Doc/VTBuilder/overview.html)
Brent Fraser
----- Original Message -----
To: gdal-dev at lists.maptools.org
Sent: Tuesday, November 14, 2006 3:25 AM
Subject: [Gdal-dev] GeoQuadTree - an open format for storing georeferencedimages
Some time ago I needed the retrieval from very large georeferenced raster images in a OGC WMS server, and I wanted to avoid the use of tile indexes or catalogues of images, neither a database. I started thinking of an open format for storing arbitrarily large georeferenced images. I named this format "GeoQuadTree", as it would be based on a quadtree of rectangular tiles, each in PNG format on the filesystem, in a simple hierarchical structure of folders. I wrote a command line utility for creating it, importing from PNG/JPEG/TIFF and exporting to PNG/JPEG/TIFF/GDAL. I also wrote a GDAL driver for this format. I tested successfully with my own WMS server software, and on MapServer compiled with GDAL support. It worked very well on Blue Marble Next Generation at a resolution of 15 arc-seconds, i.e. 86400x43200 pixels.
You can find more information on the project web site:
http://geoquadtree.org/
I'm testing the release 1.0.0, you can test it on the subversion repository if you want (I haven't packaged it yet).
I think it's a useful format, open, very easy to use, and very efficient (in terms of response time).
Do you think it could be useful for you ? Would you like to include it on GDAL's next release ?
jordi at geoquadtree org
Gdal-dev mailing list
Gdal-dev at lists.maptools.org
http://lists.maptools.org/mailman/listinfo/gdal-dev
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20061114/c92e66ae/attachment.html
